How do I replace my broken screen
My screen is busted
Esta é uma boa pergunta?
Hi @uhonesingo
Here's a video that shows what to do.
If you only want to replace the LCD screen + digitizer, search online for GH82-36146A to find suppliers that suit you best.
If you wish to replace the complete display assembly then there are two options GH82-36143A and GH82-36144A Just so that you're aware, if you decide to replace the complete display assembly, that there's a subtle difference between the two displays e.g. the colour of the frame and also the country that the phone is used in so there may be problems after replacing the screen if you get the wrong one. Check if there's a model number on the back of the original screen to verify before ordering perhaps
Esta resposta foi útil?
Hi! To replace your broken screen, first confirm your exact phone model before ordering parts. You don't want to get stuck with the wrong one. You can either replace just the LCD/digitizer or the full display assembly, but make sure the replacement part matches your device to avoid compatibility issues.
PS. Either watch helpful videos coz you better be good at it or you will end up with a lot of mess :-)
Últimas 24 horas: 1
Últimos 7 dias: 23
Últimos 30 dias: 85
Ao todo: 426
1 comentário
Dropped my phone craked top right corner no it won't work.
por Corwin DeClay Compartilhar
