Ir para o conteúdo principal
Tv is not getting on
When we were watching it automatically switched off and we started it again by putting on button after 5 minutes also it didn't on
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@shekhardhupe sounds like your power board may have failed. Let us know if you still have the power LED turn on. IF not, remove the back cover after you unplug your TV. Then check the power supply and look for the fuse on that. Measure it to see if it still has continuity. Also, take some good pictures of all of your boards so we can see what you see and hopefully we can get your TV back to working again.
Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
shekhar dhupe será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 16
Ao todo: 123
