Ir para o conteúdo principal
Guias de reparo e instruções para o MacBook Pro 13" com Apple Silicon de 2ª geração (chip M2) e tela Retina de 13,3". Modelo A2338. Lançado em 15 de julho de 2022 na WWDC 2022, junto com o MacBook Air M2.
My touchbar stopped working
my 2022 m2 13 inch macbook pro touchbar lights up but doesnt respond. all keys work, esc and touch id work, only thing is touchbar not responding but responding to screen (safari, imessage, etc)
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
Did you get it wet? Trying to clean it or something.
por
i didnt get it wet, it also isnt dirty. it hasnt work for a year
por
Adicionar um comentário
1 resposta
Sadly, the issue is likely a damaged display from a bang. The easiest way is to replace the upper case assembly, but that's quite costly while it's possible to find the TouchBar part it's a bear to take off the broken one to replace. This part is starting to become hard to find. The last option is to try to locate a junker which still has a good uppercase to swap-out or just live without the it using an external keyboard to gain access to the inputs it offered.
Here's the full repair manual with the needed parts info 2022 13" MacBook Pro service guide
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ethan Luessow será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 26
Ao todo: 170
