Ir para o conteúdo principal
Uma câmera digital compacta lançada em fevereiro de 2009. Possui tela de 2,5", sensor de imagem de 10 MP, zoom óptico de 3X com estabilização de imagem e detecção de rosto. Disponível nas cores prata, cinza-escuro, laranja, verde, rosa e azul.
Canon Lens Will Not Retract
For context, my friend gave me this ixus 95 (Sd1200) camera to keep, and it said to replace the battery so i charged it up, and it worked fine. When i tried to use the autofocus function, since it was still blurry, it wouldn't work, so i kept trying and eventually the camera effectively crashed, leaving the lens extended, now every time i power it on, it does a couple clicking noises then hands me a lens error. I was looking at the lens and the gap between the lens itself and the casing it a little uneven. I want to know if there is anyway to fix it. (for added context, my friend had it in their room for a while and its been a while since they tried turning it on.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@propanepropane sadly enough this is a common error with any digital camera that utilizes a telescopic lens. Look through the suggestion on here Fix#4 might work for you.
if it can't be corrected you will have to repair/replace the lens. For that use this guide Substituição do conjunto da lente da Canon PowerShot SD1200 IS
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Propane (Propane) será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 38
Ao todo: 182
