Air conditioner not.working
After replacing tipm my air conditioner is no longer working. Replace relay, its fully.charged but.still doesnt work
Esta é uma boa pergunta?
If the A/C stopped working right after replacing the TIPM, the issue is likely related to power, programming, or communication rather than the refrigerant charge itself.
A few things to check:
Since you already replaced the relay and confirmed the system is charged, I would focus on electrical diagnosis next. A multimeter or scan tool will help much more than replacing more parts randomly.
Esta resposta foi útil?
Últimas 24 horas: 3
Últimos 7 dias: 19
Últimos 30 dias: 40
Ao todo: 243
This question was migrated from https://meta.ifixit.com/Answers.
por iRobot Compartilhar
Hi @kathy21141
As you mentioned replacing the tipm, I assume that the air con is in a motor vehicle.
If this is correct, what is the make, model and year of the vehicle?
Moderator.
por jayeff Compartilhar
@jayeff 2019 dodge grand caravan
por Kathy Compartilhar
@kathy21141
Does the blower motor work when you turn on the air con?
Can you hear the compressor clutch operate when you turn on the air con - with the engine idling there should be a clunk sound as an electric clutch engages the compressor pulley so that the serpentine belt turns the compressor?
