Why am I stuck in a boot loop
The laptop is in the boot menu when I press the processor it should boot with it doesn't
Esta é uma boa pergunta?
Well I will suggest you to checkout the following guide: https://www.systweak.com/blogs/fix-compu...
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 40
Ao todo: 132
1 comentário
Hi @johnoybeckford
There's only one CPU in the laptop.
Can you get into BIOS OK on startup?
Have you got 2 Operating Systems installed in the laptop e.g. Windows and Linux in a dual boot arrangement?
If so are they on the same SSD (different partitions) or have you installed a 2nd SSD in the WWAN slot where one of the OS is installed?
Which OS is not booting?
por jayeff
