Prinhead removal and replacement
How are the printheads removed from a HP Officejet Pro L7580?
Esta é uma boa pergunta?
Hi @lesliebond
Here's the ifixit Desmontagem analítica da HP Officejet Pro L7580 guide that might help.
Also a link to the parts list if needed. Search online using the part number of the wanted part to find suppliers that suit you best.
Esta resposta foi útil?
Slide open the cartridge access door. Pull out all of the ink cartridges and then flip up the grey lever/handle that tha print heads rest on. Then you can carefully pull out the print heads straight up.
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 31
Ao todo: 108
