Ir para o conteúdo principal
Informações de reparo para a geladeira Samsung RF28R7201**—uma geladeira de quatro portas com profundidade total de 2019, com acabamento em aço inoxidável ou aço inoxidável preto.
Need help identifying a part
Brand: Samsung
Model Number: RF28R7201SG
Main Symptom: Need help to identify a part
What happens & when: NA
Error Code (if any): NA
Parts or tests already tried: NA
Photos / video link: SamsungIceMakerPart - Google Drive
Trying to identify this part. It is a bit melted from when I used a heat gun to melt some ice ('I know, bad idea). This is the plastic piece that protects the Styrofoam surrounding the freezing element in the Ice Master ice maker. It goes around the element and the foam. The auger assembly actually slides into this and the fan mates up with the bottom.
Esta é uma boa pergunta?
Pontuação 0
7 comentários:
Did you try plugging in fridge model into Samsungparts.com's site? Samsung may have spare parts otherwise other online distributors may carry parts.
por Compartilhar
Yeah, ive looked at a couple of sites. Not really finding the part in the parts diagrams and rolling through the parts, not seeing a pic. I figure if someone knows the part name i'd have better luck.
por Compartilhar
any suggestions on where to find a non blurry parts diagram?
por Compartilhar
@paultippit
From your description is it a part of the auger case assembly?
por Compartilhar
no, I bought the auger case assembly to resolve a fan issue. It IS the plastic piece that the auger assembly slides into and it protects the styrofoam insulation around the element
por Compartilhar
Exibir mais 2 comentários
Adicionar um comentário
1 resposta
Imagem
Imagem
Imagem
Apparently it is called the 'Fixer Fan Duct' da61-08180. It also seems to be out of stock everywhere or unavailable.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Paul Tippit será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 45
Ao todo: 189
