Front right wheel shaking
Left front wheel shaking while driving
Esta é uma boa pergunta?
@navdeephothi number one thing to check ios the ire. Make sure it has proper tread, does not have any bold spots or even metal showing. Make sure it is properly balanced (Do that to all of your tires) next check your wheel bearing. Jack the car up a bit and see if you can actual move the tire left ot right. Check your ball joint. Make sure there is no play in that. After that, you will need to check the driveline i.e. driveshaft and make sure that it does not have excessive play etc. You also need to check your shocks/struts to make sure that those are not what may cause a rattle and a bounce in your wheel when driving.
I know, it all sounds like a lot and all over the place, but it's not as bad as I make it sound. Use the Front Axle Fax chapter from the FSM and start of with page #6 for the symptom Diagnosis. Then work your way through the individual checks. Let us know what you find out.
You can now get the rest of the FSM from here 2013-2020 Nissan Rogue under the Documents heading
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 44
Ao todo: 127
