How to cluster metter repiar
Cluster metter not work propel
Esta é uma boa pergunta?
@varindersin7541 you are not giving us enough information in order to help you out. We will need to know if you are referring to the instrument cluster and what the exact issues with it are. For now what you want to do is look through the chapter for the 2004 2010 Suzuki Swift Instrument Cluster and see if that helps you to narrow it down. Most cluster issues are failed components on the cluster PCB and/or a short on the cluster PCB.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Ao todo: 51
