Ir para o conteúdo principal
Loose USB-C charge receptacles
Both USB-C side-by-side charging ports will charge laptop only if wiggled, and no power light next to ports. Need part number, and whether this is a pluggable part, or requires soldering. Thank you! A part picture would be handy.
Found that even though connector seemed fully inserted, it was not. Cleaned receptacle with narrow, stiff brush, and contact cleaner several times ...it is now charging again.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@m7vtuqoqzqrwbhl those ports are commonly soldered to the motherboard. WE will need to know your exact computer model as well as what motherboard it has. That way we can most likely find replacement ports. It may also be possible to just resolder the ones on your board. wE will have to see all of that to be certain. Post some well focused pictures with your question so we can see what you see.
Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
C H será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 83
