Ir para o conteúdo principal
Lançado em 5 de outubro de 2021 204 g, 8,8 mm de espessura Android 11, até Android 13, MIUI 14 128 GB/256 GB de armazenamento, sem entrada para cartão
Power button not working it went inside
Power button not working and went inside
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
What happened to the power button? Went inside where? More info would be useful when trying to get help.
por
@somerandomguy_1 If I had to guess, I'd say they mean that the power button is stuck, but yeah, more information would help.
por
@fixerofstuff Good point. @naraharise87483, does the button feel like it's jammed by dirt, or did it sink in after a drop? If the button still "clicks", you might want to use Isopropyl alcohol on a Q-tip to clean it; otherwise, the motherboard might have shifted inside the case, causing the button to get stuck underneath the screen.
por
Adicionar um comentário
2 respostas
Hi, @naraharise87483 I gotchu.
I would say to use some tweezers from a Precision Tweezers Set and try tweezing the power button out.
Also try opening the phone and locating the power button.
Imagem de Three slim tweezers for holding and manipulating small and delicate components. Blunt, pointed, and angled versions. Ergonomically shaped and ESD-safe. Includes a sturdy storage pouch. For electronics and other tasks where keeping a good grip is important.
Produto
$11.95
Esta resposta foi útil?
Pontuação 0
The phone's fingerprint sensor is not working.
Pontuação 0
Adicionar a sua resposta
Naraharisetty Ramchandra será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 23
Últimos 30 dias: 80
Ao todo: 483
