I have EPC on cluster
Vehicle accelerator unstable
Esta é uma boa pergunta?
@nkonzomkhize commonly the VW Golf EPC (Electronic Power Control) light with unstable acceleration indicates a fault in the drive-by-wire throttle system, often caused by a dirty/faulty throttle body, failing accelerator pedal sensors, Engine Speed Sensor Malfunction, Mass Air Flow Sensor Malfunction or even a bad Brake Light Switch. Your Golf could already be in limp but you are not saying :-) We also need to know what you have already checked.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 35
Ao todo: 134
@nkonzomkhize you are a person of few words :-) Only problem with that is that we do nto know what year your Golf is nor do we know what th engine size is or what type of transmission it has. We also do not know what you have checked and what you have tried, nor do we know how you got the "Vehicle accelerator unstable" message. So, if you are seriously looking for some ideas about how to possibly fix this, you will need to give us more words.
por oldturkey03 Compartilhar
