Ir para o conteúdo principal
Especificações do Infinix Note 12, modelo de 2023 Foi lançado em 06 de outubro de 2022. Possui uma tela AMOLED de 6,7 polegadas com resolução de 1080 x 2400 pixels. Utiliza o chipset MediaTek MT8781 Helio G99 (6nm), processador (CPU) Octa-core (2×2,2 GHz Cortex-A76 e 6×2,0 GHz Cortex-A55) e Unidade de Processamento Gráfico (GPU) Mali-G57 MC2.
Phone camera not working
Kaise thik kre
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
Yes it is not working I don't know why
por Compartilhar
@merryjoymeneses you are not telling us what is not working and what you have already tried. Did you read and follow the original answer? Any success?
por Compartilhar
Hi my camera phone broke. Can you help me this?
por Compartilhar
Adicionar um comentário
1 resposta
@moanas you have not told us which camera has failed. The very first thing you want to do is to try using your camera in Safe Mode. If it works in safe mode, you know that the issue is a Third-Party App that prevents access to your camera. You will have to uninstall that software.
To enter Safe Mode, hold the power button, then press and hold the "Power off" option on the screen until the "Reboot to safe mode" prompt appears. Select OK to restart in safe mode
Now, if it does not work in safe mode as well, it could very well be that the camera module has failed. Since iFixit does not yet have any guides for this, use something like this video to work on replacing the camera module.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mo Anas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 53
Ao todo: 285
