How to get rid of screen bleeding?
My display has a screen bleeding in all four corners. It's red and only visible when black/dark background is displayed. It is perfectly normal when light backgrounds are on display.
Esta é uma boa pergunta?
@razen6474 that sounds more of a display issue then anything else. The only things you can do about that is to replace the screen. Sometimes decreasing the backlight will make those anomalies less apparent but it will not fix it. Use the ACER AN515 51 SERVICE MANUAL to work on your laptop
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 13
Ao todo: 145
