Ir para o conteúdo principal
O Samsung Galaxy A71 é um smartphone Android fabricado pela Samsung Electronics como parte da série Galaxy A. Foi lançado em janeiro de 2020. Versões: SM-A715F/DS, SM-A715F/DSN (Global), SM-A715F/DSM (Rússia).
The device cannot be charged
The device cannot be charged by just any charger, not even its original charger; it requires a powerful 30W charger. However, if left charging for an extended period, the battery may discharge and its level may drop.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Well, could be the charge board or the battery.
Does it recognize the charger? If not, you need to replace the charge board.
If yes, you want to replace the battery.
You can follow this guide for some more info: Samsung Galaxy Not Charging
Please let us know how it goes!
Esta resposta foi útil?
Pontuação 1
2 comentários:
I replaced the charging board, the battery, and the flex cable connecting the charging board to the motherboard, but it didn't work. This problem started after I used a low-quality car charger. Thank you for your reply and attention.
por Compartilhar
Alright, well you did what you could and replaced everything "charging" related. At this moment I suspect that it's motherboard related...
por Compartilhar
Adicionar a sua resposta
Majid Korkli será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 112
