Ir para o conteúdo principal
Need help identifying Buck ic
I have an Xbox series s that was no power. It had a short on the 12v line and after probing around and a couple other non related stuff I had found that a buck ic was shorting the 12v. I could only get 1 very terrible picture of it before removing it and at the same time removing the markings.
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
@samsonmccarthy the IC missing is a RT6256CH in a QN12 package. It is a PMIC - Voltage Regulator and here is the RT6256BH CH Datasheet. Looks like it is available at places like this and many others.
Imagem
The marking on this are for the TI IC which is the same IC just different manufacturer. It's a 5V regulator. 12Vin 5Vout
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Samson Mccarthy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 37
Ao todo: 270
