Ir para o conteúdo principal
O Golf Mk5 foi introduzido na Europa no outono de 2003, chegando ao mercado do Reino Unido no início de 2004. Na América do Norte, a Volkswagen trouxe de volta o nome Rabbit quando introduziu o veículo em 2006.
Windshield washer not spraying
When I turn on the spray for my windscreen it doesn't turn on
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@tlotlonfila it will help us to help you if you can tell us if it works in the back but not the front etc. Also, let us know if you hear the pump when you activate the washer.
If it does work on one side but not the other, we know it is not a fuse and not the pump. In that case you would need to check the tubing for any leaks etc. First check you want to do, is to see if you get water to the nozzles. Remove the tubing on the nozzle and see if you now get water coming out. If so, it's your jets.
If you have no water coming out, it could be the pump or the relay under the dash. Check this video for an idea on that.
Since we do not yet know what works and what dose not, the fuse for the windshield washer pump should be #41 (also check #46) in the passenger compartment fuse box. VW Golf Mk5 Fuse Box
Imagem
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Tlotlo nfila será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 26
Ao todo: 170
