Ir para o conteúdo principal
15.6-inch business laptop from Lenovo’s V Series, powered by Intel Celeron or Pentium processors (Jasper Lake platform). Identifiable by the “V15 G2 IJL” model designation printed on the bottom chassis.
Gray Screen when turned on.
My Lenovo Laptop had a boot error and now only had a gray screen when turning on.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi @wesselhart36816
Can you get into BIOS on startup with a working display?
por
Adicionar um comentário
1 resposta
@wesselhart36816 we need to know what kind of boot error. The grey screen means that the backlight turns on but no video displays. This could be a GPU (motherboard error) or a bad screen. For now, connect an external monitor and see if that display's properly. If it doe the issue could be your screen (display cable, display connector). If it does not, the issue is most likely related to your GPU. Let us know what you find out.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Wessel Hartzenberg será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 18
Ao todo: 35
