Ir para o conteúdo principal
Informações de reparo e desmontagem para o e-reader Libra Colour da Rakuten Kobo, lançado em abril de 2024. Identificado pelos números de modelo N428 ou N428B.
Is it a software or hardware issue? Image attached
Hello! When I took my eBook out of its case, the screen looked like this. It has been exactly one year and one week since I bought the device, so it’s no longer under warranty.
I need help to know whether you think the screen is broken and I should buy a replacement and repair it, or if it could be a software issue.
I haven’t dropped it or hit it, but it was inside my backpack.
Thank you very much!
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
yes that is a broken display, it would need to be replaced.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thanks a lot! wish me luck replacing the screen by myself hahaha
por
@isdt good luck! use heat and 99% isopropyl alcohol (in small bits), it may help loosen the adhesive.
just make sure to check and see if the displays come as a digitizer with the display, or separately. some devices are laminated together and you cant just replace one or the other and both need to be replaced as one piece.
por
Hi @isdt
The screen is broken and will need to be replaced.
Depending on which model you have here are the ifixit Substituição da tela do Kobo Libra Colour (N428) and the Substituição da tela do Kobo Libra Colour guides that will help.
If you have the N428 variant, then ifixit have the screen assembly in stock but not for the N428B version it seems.
Imagem de Kobo Libra Colour N428 Tela
Guia
Nível de dificuldade:
Moderado
45 minutes - 1 hour
Imagem de Kobo Libra Colour N428B Tela
Guia
Moderado
45 minutes - 1 hour
Pontuação 0
Adicionar a sua resposta
ISDT será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 19
Ao todo: 173
