Ir para o conteúdo principal
O Neato XV Signature é um aspirador de pó robótico programável. Ele é compatível com aplicativos de smartphone para agendamento e limpeza remotos. Número do modelo: 910-0113.
No text on display
This unit has never been used. It was a family members who passed away and was never used. It is powering up and the display back light is on, but there is no text. I’ve gone through all the trouble shooting. I believe I need to order a new LCD for the unit. How do I do that for such an old unit?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @rhondawill91284
You didn't specify what troubleshooting methods you did but did you try performing a soft and/or hard reset on the cleaner?
If not and if still no good after trying a hard reset, it may not be the display that is the problem it still could be a software problem in the cleaner.
Try connecting the cleaner via a USB connection to a Windows PC and see if it responds.
Here's the Neato programmer's manual, a direct download link to the necessary proprietary USB drivers and a download link to a HyperTerminal program that may help with this.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Rhonda Williams Mack será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 38
Ao todo: 156
