Remove alternator from engine
I have alternator broke but can't find space to pull the alternator out
Esta é uma boa pergunta?
@donaldmart53225 here are the instructions for the Generator Removal from the workshop manual. If there is anything in the way etc. you want to go ahead and post some good pictures of your situation. That way we can see what you see and hopefully find a solution. Adicionar imagens a uma pergunta já existente
@donaldmart53225 all the wires are loose and your removed all the bolts etc.? Where are you stuck? You normally are supposed to drop the engine. Take a look on here to see how to try and do it without dropping the engine, or on here where you drop the engine.What a PITA
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Ao todo: 205
1 comentário
Alternator is loose but I can't get out frustrating
por Donald Martin Compartilhar
