Ir para o conteúdo principal
Informações de reparo para a sexta geração do Nissan Altima, cobrindo os anos-modelo de 2019 até o presente.
How do I replace a thermostat?
Where is the thermostat located and how do I replace it?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @clinton38566
What is the engine size and which thermostat do you need to replace?
Reason for asking is the 2.5L engine has 2 thermostats whereas the 2.0L engine only has 1.
Esta resposta foi útil?
Pontuação 2
3 comentários:
It's the 2.5L. I believe its the main engine thermostat, since its the one that works with the heater core. I currently don't have heat in the car and was advised that this is most likely the reason.
por Compartilhar
@clinton38566
The video in the blue link above shows a thermostat in the engine block being replaced at 3:26 minutes
por Compartilhar
@jayeff Thank you. I'll check it out.
por Compartilhar
Adicionar a sua resposta
Clinton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 89
Ao todo: 591
