Ir para o conteúdo principal
Lançado pela Dell em 2016, o Precision 7510 é um laptop workstation de alto desempenho. Quase todos os componentes do dispositivo podem ser substituídos ou atualizados.
Backlit keyboard stoped working
Hi 👋
After changing thermal paste I was putting components together and while installing the keyboard the ribbon cable for backlight was bent a little too much accidentally, now it had a small part of it that's seem broken, even though I tried to flatten it with my fingers, since then backlit won't work anymore and I get an error concerning touchpad when running the BIOS ' diagnosis, which I believe is normal since both touchpad and keyboard are connected to the motherboard using one ribbon cable (touchpad and keyboard work fine)
the cable is the far right one is the one for backlit :
Is there a way to fix it at home ?
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @wryyy
The cable for the keyboard backlights is integrated in the keyboard and is not a removable cable that can be replaced. Besides which the cable isn't available as a spare part.
You will have to replace the keyboard to resolve the problem.
Search online for 383D7¹ to find suppliers that suit you best.
Usually the Dell part number can be found somewhere on the underside of the keyboard, if you wish to verify the keyboard part number before ordering.
Go to p.14 in the owner manual to see how to remove/replace the keyboard in the laptop.
¹ The keyboard is used in a lot of different Dell laptops. Make sure that the seller shows your model in the ad or other models that you know that the keyboard is compatible with. Here's a link that shows what I mean. (Note: the link is not an endorsement of the seller, merely an example of what to look for).
Esta resposta foi útil?
Pontuação 1
Well I will suggest you to checkout the following video:https://www.youtube.com/watch?v=BNBxoPER...
Pontuação 0
Adicionar a sua resposta
Wryyy!! será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 191
