Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para Samsung Galaxy A05. Aqui você recebe tudo o que precisa para consertar por conta própria o seu Samsung Galaxy A05.
Phone not turning on
During a software update...it just randomly shutdown and has refused to turn on since then
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Start out by trying a forced restart of the phone. Hold the Power and Volume Down buttons for about 20 seconds. Charge it for 30-60 minutes then try again if it doesn't work.
If that doesn't help, try wiping the cache partition. This page will give you more information about that process.
Samsung Galaxy Frozen Screen - iFixit Troubleshooting
Try those two steps and let us know if they work or not. You may end up needing to connect it to a computer and doing a full restore (hopefully you have a backup), but try those things first.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Help me please
por
its because your battery is broken
Pontuação 0
1 comentário:
@lamealerte, thanks for trying to help, but the poster specifically mentioned that the problem started after a software update, so the place to start troubleshooting is with software, not hardware. There's no indication of a problem with the battery at this point, so I wouldn't have suggested a bad battery as the cause, myself.
por
Adicionar a sua resposta
Israel Umanah será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 21
Últimos 30 dias: 109
Ao todo: 337
