Ir para o conteúdo principal
Is there a Digitizer replacement for this model?
I am looking to find the correct digitizer part for ipad air (4th generation) wifi. A2316. I see the listing only for ipad air generically. iPad Air Screen Digitizer
Don't see one specific to 4th gen model. Are these parts compatible ? Thanks.
Imagem de Replace a front panel assembly compatible with iPad Air. Assembly includes the glass touch panel (digitizer), blank home button, camera bezel, and adhesive.
Produto
$29.99
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
The older models had a separate digitizer which was part of the cover glass as you noted from the original iPad, the newer iPad Air models use an integrated cover glass/digitizer/LCD screen assembly iPad Air 4/5 Screen and here's the guide to put it in Substituição da tela do iPad Air 4 you'll also need the adhesive strips to mount it properly.
Imagem de Replace a scratched or cracked front glass digitizer panel or a malfunctioning display on your iPad Air 4 or iPad Air 5.
Produto
iPad Air 4/5 Screen
$169.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Arun Natarajan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 65
Ao todo: 424
