Ir para o conteúdo principal
O receptor AV de cinema em casa 5.1 VSX-421 possui decodificação de áudio HD, HDMI V.1.4a (3D e ARC), entrada mini-jack de 3,5 mm para iPod e 120 watts de potência de saída
VSX-421 problem when powering from standby-mode
Hi, I have this reciever, I bought it faulty and replacing relays fixed all the problems but this one:
Reciever works normally until I turn it off/ put it in standby-mode and let it sit for some time. After that when I power it up it turns on but goes off in like 2 seconds. I have to reset it 1-3 times with enter+standby-button and after that it works again normally until I turn it off and let it sit for some time in standby-mode. I have not founded a schematic for this so it's difficult to troubleshoot. Inside it all looks really clean and no bulging capacitors or anything. When I press preset+standby, it gives only these: DC: 039, temp1: 00, temp2: 00, Over: 255. I have no idea what these mean :D How would you proceed to troubleshoot and can anyone tell me where to find the schematic for this model? Thanks!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
@funtimesfinn sounds like it is losing the settings while in standby. According to your DC: 039, temp1: 00, temp2: 00, Over: 255:
DC: 039 = number of DC error detections is 39
temp1: 00 = number of abnormal temperature error detections = 0
temp2: 00 = number of abnormal temperature error detections = 0
Over: 255 = Number of Overload error detections = 255
you got a lot of Overload errors and you may need to start with that.
You can now find the SM on this page Pioneer VSX-421-K under the documents tab. The RRV4183 manual must be used together with the RRV4167, so download both of the manuals.
Check the service mode section starting on page 48 and reset all of those. Then run your receiver through the usual routine. Evaluate the latest errors and check those conditions that may now be listed when you place your receiver in service mode.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Hey thanks! I'll start with these and let's see if I can find something.
por
Adicionar a sua resposta
FunTimesFinn será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 210
