Ir para o conteúdo principal
Informações de reparo, desmontagem e resolução de problemas para o smartphone Android TECNO Spark 20, identificado pelo modelo TECNO KJ5.
How to repair charging port
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
1 resposta
@mikewest61391 since iFixit does not yet have a specific guide for that, use something like this video Slow it down and the music is bit to much a well :-) Start at 5:55 and you will see around 7:50 how to remove the charging board (also called Sub or daughter board). You do not need to remove the main board nor the battery for this. Be forewarned, this phone uses a lot of adhesive on the back cover.
Replacement charging boards are readily available at many online places.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mike West será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 16
Últimos 30 dias: 148
Ao todo: 581
