Ir para o conteúdo principal
Guias de reparo e suporte para lavadoras Kenmore.
Kenmore direct drive washer
Banging noisily when in the spin cycle
Update (12/13/25)
My bad, the Model # is 110.29422801
Top loading Kenmore washer
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Kenmore sells a LOT of washing machines, and Sears doesn't actually make their own, so that means several manufacturers as well. We can't really give you good advice without knowing which one you have, so please edit your question or add a comment letting us know what the model number on your washer is.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @johnnie97371
Could be either faulty suspension springs and possibly the counterbalance springs as well.
Here are videos that shows how to replace the suspension springs and the counter balance springs that may help so that you can check if they're OK or not.
If replacement parts are needed, search online for WP63907 (suspension spring part number) or 285901 (counter balance spring part number) to find suppliers that suit you best.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Johnnie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 26
Ao todo: 120
