Ir para o conteúdo principal
A Kia apresentou a segunda geração (JB) no início do ano modelo de 2005 na Europa e no ano modelo de 2006 na América do Norte, baseada em uma plataforma redesenhada compartilhada com o Hyundai Accent.
What is mean The P2096 error code?
Check Engine Light
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@geenhammod P2096 stands for “Post Catalyst Fuel Trim System Too Lean". That means your Kia is getting too much air and not enough fuel which creates a lean condition.
This could be caused by the fuel system not delivering enough fuel (i.e. bad fuel filter, fuel pump or fuel injectors, failing Mass Airflow sensor) It can also be caused by a engine vacuum leak or an exhaust leak, a bad O2 sensor as well as a bad catalytic converter.
Let us know what exact year, engine size, and mileage for your Kia is so we can try and find more specific model information on how to proceed with the troubleshooting. Also, let us know how it runs since that might help to narrow it down as well.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
geen Hammod será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 9
Últimos 30 dias: 36
Ao todo: 336
