key button not working
Esta é uma boa pergunta?
Hi @fzengo
Sounds like there's a problem with the control panel assembly.
You could try opening the oven and removing the control panel and then check if you can open the panel to see what's wrong.
Alternatively search online for a replacement control panel. Search for DE94-03322M to find suppliers that suit you best. (examples only). This is the part number for the control panel in the oven
Be safety aware when working inside microwave ovens. The HV capacitor in the oven can store >5000V DC for months, even if the power has been disconnected for this length of time. This amount of voltage can seriously injure you. The HV capacitor needs to be correctly discharged as soon as it can be accessed after the oven's cover has been removed and before commencing any further work inside the oven. If you don't know what you're doing, then don't do it! Contact an appliance repair service and ask for a quote.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 83
Ao todo: 725
3 comentários
Hi @fzengo
What is the model number of the microwave oven?
Which buttons aren't working?
por jayeff Compartilhar
Model # MS14K6000AS
por fzengo Compartilhar
Currently now all buttons are not working
