Ir para o conteúdo principal
O Game Boy foi lançado em 21 de abril de 1989 no Japão, seguido pela América do Norte em 31 de julho de 1989 e, por último, na Europa em 28 de setembro de 1990. Ele é caracterizado por um grande invólucro cinza e o número de modelo DMG-01.
Screen not displaying correctly
When I turn my gameboy on the screen has a big black box on it. If I put a game in it makes the Nintendo ding but nothing happens. I’ve attached pictures of the screen. I’m assuming it’s a gameboy issue and not a game issue or is it a both issue? Is it fixable !?
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 1
3 comentários
@claired63511 your attached pictures do not show. Use this guide to add pictures. Adicionar imagens a uma pergunta já existente.
"big black box on it" is usually a screen issue
por
I’ve added them now, sorry!
por
@claired63511 thank you for doing that.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@claired63511 that indeed looks like a bad screen; those vertical lines are a petty good indicator that your screen has failed. The repair is not terribly complicated and there is a great guide for it Substituição da tela do Game Boy
Check online for replacement displays
Esta resposta foi útil?
Pontuação 1
3 comentários:
Hi!
To add: under the screen you have a black piece of tape, remove this completely and then you can use the soldering iron with some solder on it on that spot. Just move your soldering iron from left to right and backwards, now you shall see that the lines are coming back again! Don’t hold your soldering iron too long on a spot, otherwise it will get burned. Do this many times, till you have all the lines back :)!
Sometimes, this method won’t work anymore or the lines are dissapearing again, if this is the case, you need to replace the screen..
Good luck with the repair!
por
@dan0 brother fixer you need to make a guide for that :-) That would be awesome!
por
@oldturkey03 good one! Will do that when I need to repair one again :)! I think next month I can create a guide about this!
por
Adicionar a sua resposta
ClaireD será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 242
