Mouse pad is stuck
My mouse pad is stuck and the left click is constantly pressed which makes the pad unusable
Esta é uma boa pergunta?
@ghost47490 start off by checking and adjusting the settings for your touchpad.
Through Windows Settings:
Through Control Panel:
If none of that will make a difference I would consider removing and checking the touchpad for and physical damage and/or replacing it. Use the HP Victus Maintenance And Service Guide and on page 59 it tells you how to work on it.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 48
Ao todo: 866
