Ir para o conteúdo principal
O Xiaomi Redmi Note 10S é um smartphone intermediário da Xiaomi lançado em março de 2021. Ele possui um display eletrônico AMOLED de 6,43", uma câmera traseira de 64 MP, sensor de impressão digital montado na lateral, bateria de 5000 mAh e roda com o Mediatek Helio G95.
Display does not respond correctly to touch
More than two weeks ago, my father had his display replaced because his phone fell and broke the display, but since they replaced the display, he went back to the service centre because the display does not respond correctly to commands. Sometimes it does its own thing. I thought it was a dirty display, but cleaning it does not solve the problem.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@piero90 that sounds very much like a bad touchscreen/LCD assembly. Since this happened right form the beginning I would strongly suggest that your dad has the service center replace it once more with a proper replacement. This will not get better on it's own, there are no calibrations or adjustments.
Esta resposta foi útil?
Pontuação 0
5 comentários:
My father went to a service centre twice.
por Compartilhar
@piero90 they did replace the screen already?
por Compartilhar
@oldturkey03 yes, twice
por Compartilhar
@piero90 sorry to hear this, but something like "Sometimes it does its own thing." is pretty much a sign of a bad display assembly. Let's see if there are other answers that come up with a different idea.
por Compartilhar
My father went to the service centre for the third time to have the display replaced, but the problem persists, so I assume it is a logic board issue.
por Compartilhar
Adicionar a sua resposta
Piero Sabino será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 30
Ao todo: 278
