Ir para o conteúdo principal
A atualização de março de 2015 do MacBook Air de 11" da Apple apresenta processadores Intel Core i5 e i7 de quinta geração, resultando em um ligeiro aumento de desempenho e autonomia da bateria.
Trackpad suddenly not clicking
Hi, so I’ve had this laptop for over a decade and I’m determined to keep using it until it literally explodes, so a few weeks ago I got a replacement battery from here & installed it. It’s been great & I haven’t had any issues, but today I went to use it as usual and suddenly my trackpad wasn’t clicking. I could double tap & move the mouse but the actual click sensation is gone. I spent an hour troubleshooting, restarting the computer & reinstalling the battery but the problem persists & diagnostics turns up nothing. Any suggestions would be appreciated, thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You could try to adjust the small screw that sets the trackpads position located at the lower center of the case (It is hard to miss) to see it that helps, failing that remove the trackpad and give the edges and the case edges a good clean up, then reinstall it. Check also the cable that connects to the logic board, these can become creased or suffer damaged pins quite easily. Trackpads can fail over time so if the first options didn't solve it then it would likely need a fresh trackpad and cable.
Imagem
Substituição do trackpad do MacBook Air 11" início de 2015
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thanks! I messed with the trackpad screw for a few minutes with the display on until I got a tension that worked!
por
@jets96744 Good to hear :)
por
Adicionar a sua resposta
Jet S será eternamente grato(a).
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 39
Últimos 30 dias: 103
Ao todo: 583
