Ir para o conteúdo principal
Informações de reparo, desmontagem e resolução de problemas da família de smartphones Android Infinix Smart 7, incluindo o modelo Smart 7 HD Infinix X6516.
Infinix smart 7 screen broke
My phone suffers a high long drop to the ground and the screen becomes half way blank
Esta é uma boa pergunta?
Pontuação 6
7 comentários
Display problem
por
My phone battery is not good
por
@adnanazlan replace the battery and then re-check.
por
My phone display is broken
por
Did you read the answer provided by @oldturkey03? Unless you have a different phone from the original poster, it has all the information you need to replace your screen.
por
Exibir mais 2 comentários
Adicionar um comentário
2 respostas
Pergunta mais útil
@hussainium73365 sounds like you have a broken screen that will need to be replaced. Since iFixit does not yet have specific guide for that, use something like this video Replacement LCD's are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 2
That means the screen is broken
Pontuação 0
Adicionar a sua resposta
Hussaini Umar Musa será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 59
Ao todo: 686
