Ir para o conteúdo principal
O Toshiba Chromebook CB35-A3120 é um laptop de 13,3 polegadas com tela de 1366x768, projetado para uso doméstico e educacional.
Why is the LED light blinking while charging
The Chromebook is blinking on the LED light as it charges and continues to do so and when I unplug it it turns off as it's not charging at all
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Your Chromebook issue points to a charging or battery fault. First, try a hard reset by holding Refresh + Power for 10 seconds while plugged in. If it still shuts off when unplugged, the battery may be dead or disconnected. Check the battery connection inside (if accessible). If reseating doesn’t help, you likely need a battery replacement. If under warranty, contact support; otherwise, take it to a repair center.
Esta resposta foi útil?
Pontuação 1
Hi @lemuel48770
Most likely the battery has failed and needs to be replaced.
Here's a video that shows what to do.
Search online for PA5171U-1BRS to find battery suppliers that suit you best.
Pontuação 0
Adicionar a sua resposta
Lemuel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 28
Ao todo: 193
