Ir para o conteúdo principal
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
Why my front right wheel producing a sound?
why my front right wheel producing a sound?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi @hararelogistics
What kind of sound is it making, scraping sound, tapping sound at regular intervals etc.
Safely park the car and then jack up the right front side of the car so that the wheel is just off the ground and slowly turn the wheel by hand to check if you can hear where the noise is coming from.
Remove the wheel and then check if the brakes are OK and not that something is caught in the pads.
Be safety aware and do not get under the car when it is up on the jack. If you need to get under the car, either lower it to the ground or put it on a hoist
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Harare Logistics será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 33
