Hi @bdwest23242
If the lower door scrapes the inside of the compartment, it may be a loose lower hinge bracket, worn hinge pin or spacer.
Here's a video that shows how to replace the hinge pin that may help.
It shows how to gain access so that you can check if the bracket (bent/loose?), the hinge pin (worn?) and spacer are all OK or not.
If replacements are required, the part numbers are as follows. Search online for the part number only to find suppliers that suit you best.
lower hinge pin = 240516502
spacer = 240311303
lower hinge bracket = 240314011
Note: The refrigerator is a Frigidaire model, made for Kenmore as it is made entirely from Frigidaire parts. That's why parts results show Frigidaire name. Kenmore doesn't make appliances, they rebadge/made to order other makes of appliances e.g. LG, Frigidaire, Whirlpool etc
Hi @bdwest23242
What is the model number of the refrigerator?
por jayeff Compartilhar
253.67879509
por Bdwest Compartilhar
