Ir para o conteúdo principal
How to change screen
How to change my broken screen
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Before you begin
  • Source a replacement screen: Find a new LCD and digitizer assembly by searching for "Infinix Hot 10i screen replacement" on sites like eBay, Amazon, or Alibaba. Note the model numbers (
  • X659B
  • X658E
  • , etc.) for compatibility.
  • Test the new screen: Before installing it, test the replacement unit by temporarily connecting it to the motherboard. Power on the phone and check that the display and touch functions work correctly. Do not install it if there are any issues.
  • Gather tools: You will need a heat gun or hair dryer, a prying tool, small screwdrivers, and an anti-static wrist strap to prevent damage to internal electronics.
Screen replacement steps
  1. Remove the back cover: Apply heat to the edges of the phone's back cover to loosen the adhesive. Use a prying tool to carefully separate and remove the back cover.
  2. Disconnect the battery: Open the phone to access the battery connector. Use a pry tool to carefully disconnect the battery to prevent any electrical shorts during the repair.
  3. Detach the old screen: Apply heat to the edges of the broken screen to soften the adhesive. Use a prying tool to carefully separate the old screen from the frame. Be careful of glass fragments.
  4. Clean the frame: Remove any old adhesive and debris from the phone's frame to ensure the new screen can be installed flush and securely.
  5. Install the new screen: Apply new adhesive to the frame and connect the new screen's ribbon cables to the motherboard. Test the screen again before sealing it.
  6. Secure and reassemble: Carefully secure the new screen in place and re-connect the battery. Place the back cover back on the phone.
Watch a video guide
Because it's a visual process, a video guide can walk you through the steps in detail.
  • Search YouTube for "Infinix Hot 10i screen replacement" to find videos like Infinix Hot 10i Broken Screen Replacement or infinix Hot 10i Screen Replacement, Disassembly.
It is VERY recommended to get a professional repair. -Neo
Esta resposta foi útil?
Pontuação 1
3 comentários:
@neoatat If you use AI to write content for iFixit, you must check for accuracy and safety 100% of the time. Caution is essential when using AI for repairs. AI lacks hands-on experience, real-time assessment, and may provide inaccurate advice, risking worsening issues. Its static knowledge may not address evolving technologies or unique circumstances, potentially leading to unsafe situations. Balancing AI with human expertise is crucial for accurate and safe repairs. You must be transparent when you are using AI and need to address that in all your answers.
por Compartilhar
Again, I don't use AI, only 10% of the time, only for Web help. so please stop asking this question. -Neo
por Compartilhar
@neoatat I'm sorry, but according to the JustDone AI Detector,
"90% of your text “Screen replacement” shows signs of AI generation"
por Compartilhar
@onacollins74376 to replace the screen assembly, use something like this video as your guide. Replacement screens are readily available and not to expensive. Just do an online search and select a vendor that appeals to you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Pontuação 1
Adicionar a sua resposta
ona collins Nnaemeka será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 32
Ao todo: 337
