Ir para o conteúdo principal
O modelo UA40F5500AM é uma Smart TV de 40 polegadas produzida pela Samsung.
Como arrumar uma tv
Como arrumar uma tv que liga mas n aparece nada na tela
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
Como arrumar uma TV Samsung a placa mãe não está funcionando
por Compartilhar
@danielmato63701 that will depend on the make and model of your TV as well as why you think it is the main board that has failed. You have not mentioned the exact issues that your TV is having. IF we don't know what it does we really can't help you much.
@danielmato63701 isso vai depender da marca e do modelo da sua TV, além do motivo pelo qual você acha que a placa-mãe está com defeito. Você não mencionou exatamente quais são os problemas que a sua TV está apresentando. Se não soubermos o que está acontecendo, não vamos poder te ajudar muito.
por Compartilhar
Adicionar um comentário
1 resposta
@art79561 you have not told us if the power LED lights up and if it stays steady or if there is a blinking light. We will also need to know, what you have already checked and what you have tried. Also, we need to know that your TV is a Samsung UA40F5500AM and if you have any audio.
As a general rule you want to try a reset first. Disconnect everything that is plugged into your TV. Then unplug your TV. Now hold the power button down for about a minute. Now connect one video source only. Something local like a game console or a DVD/BR player will work. Connect the power back to your TV. No try to turn your TV on. Let us know what happens.
Next you want to check the backlight, just in xcase your TV is actullay turned onbut you can't see it on the screen. In a darkened room, turn the TV on Next, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adicionar imagens a uma pergunta já existente for that so we can see what you see. It is possible that this is either a power board or a T-con board issue.
Translation
@art79561, não nos disseste se o LED de energia acende e se fica aceso ou se pisca. Também precisamos saber o que já verificaste e o que tentaste fazer. Além disso, precisamos saber se a tua TV é uma Samsung UA40F5500AM e se tens áudio.
Como regra geral, deve tentar primeiro reiniciar. Desligue tudo o que está ligado à sua TV. Em seguida, desligue a sua TV da tomada. Agora, mantenha o botão de alimentação pressionado por cerca de um minuto. Agora, ligue apenas uma fonte de vídeo. Algo local, como uma consola de jogos ou um leitor de DVD/BR, funcionará. Ligue novamente a sua TV à tomada. Agora, tente ligar a sua TV. Informe-nos o que acontece.
Em seguida, verifica a luz de fundo, caso a tua TV esteja realmente ligada, mas não consigas ver nada no ecrã. Numa sala escura, liga a TV. Em seguida, usa uma lanterna e aponta o feixe de luz em ângulo contra o ecrã. Vê se consegues distinguir sombras ou formas. Se conseguires, então é a tua luz de fundo que falhou. Se não vires nada, desliga o aparelho e remove a tampa traseira. Em seguida, verifica visualmente as placas para ver se há componentes danificados óbvios. Verifica toda a fiação, desconecta os fios e conecta-os novamente, certificando-te de que estão bem encaixados. Publica algumas imagens de todas as tuas placas com a tua pergunta. Use este guia Adicionar imagens a uma pergunta já existente para que possamos ver o que você vê. É possível que seja um problema na placa de alimentação ou na placa T-con.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Art será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 156
