Ir para o conteúdo principal
O Xiaomi Redmi Note 10 é um smartphone intermediário da Xiaomi lançado em março de 2021. Ele possui uma tela AMOLED de 6,43", uma câmera principal de 48 MP, sensor de impressão digital na lateral, bateria de 5000 mAh e funciona com um Snapdragon 678.
May phone not charging
Not charging
Esta é uma boa pergunta?
Pontuação 2
2 comentários:
Not charging
por
@sam46889 have you already checked what I suggested in my original answer? what was the outcome?
por
Adicionar um comentário
1 resposta
@sadnahda you are really not giving us a lot of info here! You need to consider to letting us know if anything happened to your phone or if it just stop charging. It is always helpful if you at least tell us what you have tried and what you have checked.
Well, let's start at the beginning :-)
First, you want to check your charger. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get an ammeter and see if your phone draws any amperage from the charger.
You may also have to consider replacing the battery. A depleted battery can no longer be charged. Measure the voltage on your battery connector with the charger plugged in. You should get around 4.2V If you do not get this voltage If you don't get that voltage check your flex cable coming from the charging board. Make sure it is seated properly and does not have any tears or other damage on it. Your phone has a separate charging board that could be faulty. Consider replacing that.
To work on your phone use something like this video since iFixit does not yet have a guide for that,
Esta resposta foi útil?
Pontuação 0
3 comentários:
what if my battery shows around 3,6 v?, i have similar problem to person above, additionaly my phone sometimes popped up overheating popup, whe i ran many apps at one time
por
@jan54210 the 3.6V is a bit low and it's the battery voltage. Your voltage should be higher at the battery connector. If the voltage does not increase when you measure it and connect the charger, you know the issue is either with the charging board or the PMIC on your board. Let us know what you find out. Common issue in your case could also be a bad battery.
por
@oldturkey03 i created my own question, a lot mor detail there: phone not charging when plugged
por
Adicionar a sua resposta
Sad Nahda será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 60
Ao todo: 539
