Ir para o conteúdo principal
A Ford F-150 2015-2020 é a décima terceira geração desta picape de grande porte. Ela é conhecida pela sua construção inovadora de carroceria em alumínio, opções de motores potentes e recursos tecnológicos avançados, oferecendo um veículo versátil e capaz tanto para o trabalho quanto para o uso diário.
2016 F-150 Steering Wheel Control Module and Clock Spring
So I got my truck serviced and they confirmed these are the components that are bad. Problem is they wanna charge $900, no insurance or warranty helping, and I practically live paycheck to paycheck. Is it possible to fix these myself?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
@oldturkey03 The big problem is the left side lever (wipers, turn signals, high beams) doesn't work. Additionally all the controls on the steering wheel don't work. Less concerned about those. The big issue my brother raised about doing this at home is if the control module would need to be programmed.
por Compartilhar
Adicionar um comentário
1 resposta
@hlasley "practically live paycheck to paycheck" I think we are all doing that right now. There just isn't any extra money is there. Anyhow, what are the symptoms for your failed module? Yes, It looks like it can be done as a DIY. Looking through the service manual right now but it's to big to post one here.
My biggest concern with that is always the air bag. I would hate for that thing to deploy while you work on it. Anyhow, start with videos like this one as well as for the module itself use this video
Yes, the module will have to reprogramed by using a Forscan unit. you may need to find someone that either has one of those or you will need to depend on your dealer. May still be cheaper then what they originally quoted you.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
H. Lasley será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 45
Ao todo: 617
