How fix code p2004 problem with check engine on
Code p2004 intake manifold
Esta é uma boa pergunta?
@hassanrami actually the P2004 code stands for "the PCM has detected the bank 1 IMRC actuator is stuck in the open position" This is a common issue with your Rogue model. Nissan even issued a Service Bulletin on how to resolve this issue. Following those directions should fix your code as well
Esta resposta foi útil?
Intake manifold runner control stock open bank 1 that's scanner show me
@hassanrami IMRC - Intake Manifold Runner Control; exactly what @oldturkey03 said.
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 69
Ao todo: 987
