Ir para o conteúdo principal
LCD tv display spot
My TV display is broken, what should I do now?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@naimhossain the only way to fix that is by replacing the screen. I would remove the back cover and check for a label on the screen back. Then do a search for that by the numbers from the label. It should be possible to get a 32" panel but it may still cost a lot for shipping etc. May even cost more than a new TV. You can of course also try and find the same model TV that is broken other then the screen. Harvest the screen from that. If you have trouble finding a replacement screen, take a picture of the label that is on the inside of your TV and post it on here with your Question. That way we can see what you see and hopefully help you further. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Naim Hossain será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 131
