Ir para o conteúdo principal
Impressora laser fabricada pela HP. Utiliza o cartucho de toner 12A, que produz 2.000 páginas com 5 % de cobertura. Capacidade nominal de 15 PPM.
Why printer not picking the paper
When I give command to printer, green light blinks but suddenly red light starts blinking
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@awaismaria we will need to know which light it is that is blinking. It is possible that this is a stuck jam sensor or an issue with either the paper-delivery sensor or the top-of-page sensor. For now use the service manual for your printer model that you can now find under the Documents Tab on this page LaserJet 1012
While you work on your printer, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Awais Maria será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 19
Ao todo: 184
