Ir para o conteúdo principal
O celular Tecno Spark 6 Air foi lançado em 30 de julho de 2020. O aparelho vem com uma tela sensível ao toque de 7,00 polegadas, oferecendo uma resolução de 720x1640 pixels e uma proporção de 20,5:9. O Tecno Spark 6 Air é equipado com um processador quad-core MediaTek Helio A22 (MT6761). Ele vem com 2 GB de RAM. O Tecno Spark 6 Air executa o Android 10 e é alimentado por uma bateria de 6000 mAh.
My phone does not charge
why my phone does not charge
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@samsbits not telling us much. Things like what you have checked and what you have already tried will be important.
This can have many different reasons. First start by making sure that your charger supplies the proper voltage. Next check the charging cable. Make sure that there are no bend. broken. or corroded pins. Now focus on the charging port. A few drops of high-grade isopropyl alcohol and a few puffs of compressed air will clean out the port.
If all of this does not work, then it might be time to disassemble your phone. Think about replacing the battery as well as the USB charging port. Since iFixit does not yet have any guides for that, use something like this video Anything after that, will require some board level repair. For that you need to have the tools, the schematics and the experience to repair that.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sams Bits será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 147
