Ir para o conteúdo principal
A Canon PowerShot A460 é uma câmera digital compacta de 5,0 megapixels com zoom óptico de 4x.
Why is my screen white?
I need help please. Whenever I turn on my camera a white screen pops up. This screen stays there no matter what button I press and I’m unable to take pictures. Before that screen appeared I was looking at my pictures and the screen went glitchy and then the white screen appeared. I tried putting new batteries and a new memory card but the white screen continues to show. What should I do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@america42671 this "the screen went glitchy" and the white screen, sounds like a bad display. A white screen means that the backlight still comes on but that the display itself no longer receives a signal. Check the ribbon cables etc. to make sure everything is still connected properly. After that, you most likely will need a new screen. Use these guides Canon PowerShot A460 to work on your camera.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
America será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 39
Ao todo: 435
