Ir para o conteúdo principal
A DeWalt DW311 é uma serra sabre com fio.
How to replace power cord?
Imagem
Imagem
Imagem
Imagem
The black cord seems to be hard wired into the switch. How to separate and replace just the cord?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
@alienamerican looks like the power cord is available without the switch. That would mean that it is somehow possible to remove the cable from the switch. I wonder if there is a push connector on the switch for the cable. Post some good pictures of your switch etc. with your Question. That way we can see what you see and hopefully come up with a solution. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 0
3 comentários:
Added some photos. This little black box looks like it should open, but nothing I've tried seems to work
por Compartilhar
@alienamerican what a PITA. I absolutely dislike when they make things so complicated. Yes, it does look like it comes out. The trigger seems to operate some sort of lever that moves the contacts on the inside of the switch. Honestly, at this point I would just cut the wires, solder the new power cord to the tails and apply some heat shrink tubing for insulation.
por Compartilhar
Good idea. I'm gonna just do that
por Compartilhar
Adicionar a sua resposta
Alienamerican será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 39
Ao todo: 422
