Ir para o conteúdo principal
My CPU is overheating
Ok so I have a preebuid PC and I have
Parts:
GPU: RTX 4060
CPU: Intel i5 14600 kf
Fans: 3 intake 1 outtake fans 1 CPU fan
So I got this PC on Christmas and I saw the issue from the start 80°C from the start and then It became overheating more and more now I'm sitting 90° startup and 100°+ when gaming I think it's not bad airflow but I think they left the sticker on the CPU fan what do you think about this
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@stepan38542 you will need to check the CPU fan (Check fan speed as well as fan airflow) If that checks out okay you will need to consider replacing the thermal paste on your heatsink. Since we do not know what motherboard you are using etc., we can't really help you further with the details.
If you are using Windows as your OS you can check the fan speeds etc. with some decent programs as well. Let us know what you find out.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Stepan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 17
Ao todo: 182
